SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
SOURCE: excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
SOURCE: 2004 gp1300r jetski 20 mins riding and overheating
pull out the cat temp sensor and check to see if its bent. if so then its definently your catalist, even if not bent chances are still good it has failed. you need to be sure which light is coming on. does it look like a tube with squigly lines going up?
SOURCE: my '94 yamaha waverunner 3 runs great for the
Could be a bad temp sensor. The bog is a rev limiter to keep engine from running full throtle when hot or when there is another problem. You can bypass the temp sensor and see if that takes care of problem. The parts about 100.00. I disconnected mine a now run a temp gauge which I mounted on the right side just above oil gauge.
