Question about Yamaha 12V Air Pump
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
I have a 2002 Yamaha FX140 Waverunner. It won't start normal, won't stay idle at all and won't accellerate past 4 miles per hour. It was my fathers and not used hardly. Has total of 36 hours since he baught it. It started giving problems last year by having hard time starting and staying Idle, then this year it not only won't start without throttling and staying throttled, it won't accellerate anymore past 4-5 miles per hour , up to 4-5000rpm. I have check the injectors and it does get fuel to all four ports, but I do not know what else to check, there is no inline fuel filter, only one on the fuel pump which i have not checked yet since it has been delivering fuel.
any suggestions? how to clean the fuel injectors , low speed if clogged? or is it electronic problem limiting the engine?
Posted by pmich007 on
  • pmich007 Jul 08, 2009
    After doing several oil flushes and adding new oil I noticed a big change , but it wasn't until I did change the plugs when the watercraft came fully back to life. I would recommend both, oil flush, and spark plugs. also added some fuel injector cleaner to help clear up the nozzles. All three helped it get back to full performance.
    thanks for the feedback
Anonymous
    Champion:
  • 207 Answers
You have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Posted on Jul 08, 2009
Justin Zevely
  • 3 Answers
U need a new wear ring in your jet unit
Posted on May 08, 2018
airtempservi
Have a yamaha xlt 1200 that hasnt run in 5 years. Not getting fuel . New plugs are dry. I think its a carb problem. What do you think should be done? Should i pull out the carb and clean it? Or do i need to change something? Please advise. Thanks
Posted on Jun 01, 2012
Anonymous
Where can i locate my spark plugs on my ho waverunner 06
Posted on Aug 22, 2009
Anonymous
Don't know if this will help, check all your plugs. i had one plug go out and lost 10 mph. i was told if you start and stop more than a couple times out of water it will foul the plugs right out. give this a try!
Posted on Jul 14, 2009
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
1helpful
Starting problem on 2002 Yamaha Wave Runner FX140
Yamaha 4 stokes wont fire back up if you try to restart within 1 second of shuting it off.
2answers
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
1helpful
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Yamaha 12V Air Pump Logo
Top Yamaha Water Sport Experts
Mike
Oloyede Monsuru
johnny bonacci
johnny bonacci
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
