Linksys WMP600N Wireless Adapter Logo
Posted on May 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to access setup page to change my SSID
Anonymous
Level 2:
New Friend:
  • Expert 88 Answers
  • Posted on May 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
88
Questions
Helped
28007
Points
291
There you have user guide. Turn to page number 3 there:
http://downloads.linksysbycisco.com/downloads/WMP600N_V10_UG_NC-WEB,1.pdf
Leave rate if I helped you, thanks!!
Cheers,
Mike
How do I get a username and password.
In general, you have to use a PC to connect to the router with a LAN cable and then use the CD that comes with the router to access the setup page. Username (SSID) and password can be accessed and changed from there.
How do i setup my wireless linksys model wcg200?
The wireless settings that you need to take note of are:
a. SSID - this is the name of your wireless network
b. SSID Broadcast - an indication if your SSID is showing on the list of networks available
c. Wireless Security - serves as the password for your wireless network
To check the wireless settings on the Linksys router, follow the steps below.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router's web-based setup page. For instructions, click here. If you are using a Mac computer to access the web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless.
4678-009.png Step 3:
Look for Wireless Network Name (SSID). If it's still set to "linksys", change it to something unique then click 6-4680.jpg NOTE: Take note if SSID Broadcast is Enabled or Disabled. If it is Enabled, it means your SSID will show among the list of wireless networks available when any wireless device will search for a network to connect to. If it is Disabled, it will not be visible.
Step 4:
Click the Wireless Security subtab and take note of the current Security Mode.
If Security Mode is set to WEP:
4678-007.png If Security Mode is set to WPA:
4678-013.png You can change your WPA shared key if you want to personalize it. It should be a minimum of eight and a maximum of 63 characters long.
Step 5:
If you need more help come back.Post / thumbs / testimonial are welcome!
I want to change the name and the security password from default..but how? can anybody help me? thanks..
You can change the wireless name (SSID) and the wireless password by accessing the setup page. To access the setup page, do the following;
Open internet explorer or firefox and type in 192.168.0.1. It will ask for username and password. In the username field, type "Admin" , A in Admin should be a big letter. In the password field , don't type anything. Hit enter in yout keyboard and you will see the set-up page. In the set-up, look at the right side and click Wireless Settings and you will see Wireless Network Name (Also called the SSID) , and change that. Under Wireless Security Mode, change the wireless password or Passphrase.
HOW DO I LOCK MY ROUTER
Locking the router can be done by setting a WEP key. Its a 10 digit alphanumeric key that you can set. Once you set it up, anyone who tries to access your router wirelessly will be prompted for that 10 digit key. Be sure to change your SSID (wireless network name) also so that you can distinguish your own secured wireless network from others.
SSID can be changed on the main setup page.
1. To access it, open Internet explorer while your computer is physically connected to the router.
2. Type http:\\192.168.1.1 (the default IP address of the router.) It will ask you for the username and password.
3. Enter the word "admin" for both username and password. It is the factory default username and password. On the main setup page, you will find the field for SSID or Network name.
4. Type your unique wireless network name and click the Save button on the bottom of the page.
5. On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab
6. Click the drop-down arrow for Security Mode and select WEP.
7. Under WEP Encryption select 64 bits 10 hex digits.
8. Enter a unique word in the Passphrase field, then click Generate.
9. The result will be a string of letters and numbers displayed in the space provided for Key 1.
NOTE: Take note of what is in Key 1. This key will serve as the wireless security password. Keep this key confidential.
10. Click the Save Settings button.
From now on, whenever anyone tries to access your wireless network, they need to enter Key 1 which you only know. There you go. Your wireless network is protected.
How do i get my ssid code
By default, the SSID of the router is NETGEAR, and the wireless security is disabled.
However, if you have already changed the default settings on the router, then you can check the settings by accessing the setup page.
In the address bar of your web browser, type 192.168.1.1. Or if this doesn't work, type www.routerlogin.net.
Default username is admin. Default password is password.
Once in the setup page, go to Wireless Settings. You will see the SSID and wireless security settings.
I hope this helps!
I need to find my ssid to get internet on my psp
The default SSID is Netgear but if you have changed this to something else then you will need to access the setup page of the router.
Open a web browser to a computer that has access to the router. In the address bar, type www.routerlogin.net.
By default, the username is admin, and the password is password.
Once in the Netgear page, under Setup, go to Wireless settings.
You will be able to get your SSID and security settings from that page.
I hope this helps!
3answers
How do I change my SSID?
You log into your router and change it there in your setup. The SSID, is just the "Name" you give your "Connection"
My friend came over with her laptop and wanted to get on our network. No problem right, she entered the eight digit PIN number and was immediately connected to our network. Then when I glanced at my own...
1 if its a belkin router then open ie or firefox
2. type 192.168.2.1 in the address bar it will lead u to belkin router setup page IMPORTANT --- U NEED A HARDWIRED COMPUTER TO ACCESS THE BELKIN PAGE
3. in the belkin page on the left side click on the wifi protected setup under wireless
4. login page --- leave the password blank click submit
5. disable the wifi protected setup and click apply changes
6. then click on the channel and ssid under wireless
7. change the ssid to ur desired name thts gonna be ur network name
8. check whether the broadcast ssid is checked marked or not
9. if its checked then click on apply changes
10. then scan and connect ur network it will not ask for the pin number and u will access the internet.
1helpful
2answers
I want to put a password on the wireless connection
Access your router login page by entering 192.168.1.1 on the URL address bar, go to security and find PSPK code, that is a pre shared pass key, enter the password there and restart, now your wireless connection requires the password. Hope this will solve the problem
Bad Roomate
You can do that by accessing the setup page of the router.
You can follow these steps on how to change the name and put in a security.
Step 1:
Access the router’s web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless.
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to "linksys", change it to something unique and take note if Wireless SSID Broadcast is set to Enable.
3698-009.png Step 4:
Click Wireless Security and take note of the current Security Mode.
3698-007.jpg If Security Mode is set to WEP:
NOTE: In this example, WEP 64-Bit is used. To know more about Wireless Security, click here.
3698-013.png If Security Mode is set to WPA:
NOTE: In this example, WPA-TKIP is used. To know more about Wireless Security, click here.
3698-015.png Step 5:
Click 3698-017.png.
Or you can go to this link. if you can see the images.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
