ASUS K8S-MX Motherboard Logo
Posted on Mar 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver problem after installing latest versionsof fifa, when I launch the game the titles are not displayed, means enter, exit to windos, game menu etc..
Anonymous
Level 2:
  • Expert 152 Answers
  • Posted on Mar 27, 2008
Anonymous
Expert
Level 2:
Answers
152
Questions
0
Helped
97149
Points
299
Run dxdiag under the \windows\system32
1helpful
How to get free FIFA coins, brand-new FUT 20 coins or first-hand FIFA 20 coins?
Yeah, FIFACOIN.COM as one of the reliable fifa coin websites offering the first-hand fifa coins and brand-new fut coins now is launching the FIFA 20 Coins pre-sale activity now, and you can enjoy up to 20% off if you buy FIFA 20 Coins voucher in advance, which means that you can get more free FIFA coins at the same price as other websites. Enjoy more deals on fifa coins prices now here https://www.fifacoin.com/category-fifa-20-vouchers.html
Monitor only works on safe mode,why?
Vga drivers might have been corrupted and need to be updated.
Video drivers are applications that enhance your on-screen display. The drivers make your text and images sharper and clearer. Some devices and applications may corrupt display drivers. You can, however, repair the drivers in Safe Mode. Safe Mode is an area of Windows that only allows a limited number of applications to run, thereby making it ideal for repairing and restoring your display driver. Click the Windows "Start" menu and click the "Control Panel." Double-click "System and Maintenance" and click "Device Manager" to launch the hardware management console if you are using Windows Vista or 7. For Windows XP users, right-click "My Computer" on the desktop and click "Manage." Click "Device Manager" to launch the hardware management console. Click the "Display Adapter" to expand it. Make a note of the video driver that contains a question or exclamation mark. A question or exclamation mark means the video driver is either damaged or missing. Close the Device Manager. Write down your computer's model and serial number. The location of the serial number varies with different computer models but can generally be found on the front or back of your computer. Go to your computer manufacturer's website and locate the "Support and Drivers" section. Locate "Driver Downloads." When prompted, type your serial or model number to locate the drivers compatible with your computer. Click "Download" next to the video driver compatible with your computer. Select "Save" and download the video driver installation file on your desktop. Restart your computer and press "F8" repeatedly before Windows reloads to launch the Advanced Options Menu. Select "Safe Mode" and press "Enter" to launch Windows Safe Mode. Double-click the video driver you installed and click "Run" to install the driver on your computer. When the installation completes, go back to the Device Manager and click "Display Adapters." Make sure that your video driver no longer contains a question or exclamation mark. If the driver still contains a question or exclamation mark, right-click it and click "Update driver." This launches the launch the driver installation wizard. Insert your Windows installation CD and click "Install software automatically (Recommended)" and then click "Next." The install wizard installs the video driver automatically. Restart your computer normally when the installation completes. Hope this helps.
2answers
I downloaded fifa 2011 and i launched the game and then it stopped loading and sayd rom loading failed load rom error=-4 please reset system, how shuold i fix it
This is a non patched version. It has something to do with Antipiracy..
Solution 1: Update your r4 or card to the latest firmware
Solution 2: You will need a patched version of FIFA 2011 (not available yet)
Please give some more info about your card.
Example: Firmware Version, Card
5helpful
2answers
When i try to run fifa 11 i get an error message saying E001.how to fix this
You can try updating your graphic cards to the latest drivers from Manufacturer Site, update your DirectX to the lastest too. If you still get the errors, this means that your graphic card does not support the "Shader mode 3" to run Fifa 11. You have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps.
1helpful
2answers
I installed fifa 11 and when i try starting the game i get error e001 ... when i try to run fifa 11 i get an error message saying E001.how to fix this ...
Error e001, starting the game fifa 11
Most probably your video card does not support "Shader Mode 3 or higher".
Get a better video card.
What are your system specs? Have you updated your graphics card driver and installed the latest directx redist. In the fifa11 zip file there is a redist folder, make sure you install everything in there as well. Also, try updating your sound card driver, it may be conflicting.
Take note**
ATI Radeon HD3200, HD4350 and
Hope it helps.
How to set the scanner feature of aficio 2018
As you did not specify which scanning type, I go for the most common.
Follow these steps:
  1. On the taskbar, click [Start], point to [All Programs], point to [SmartDeviceMonitor for Admin], and then click [SmartDeviceMonitor for Admin].
  2. Click the device to which you want to add destinations.
  3. On the [Tools] menu, click [Address Management Tool].
    Log in to the device as necessary.
  4. On the [Edit] menu, click [Add New User].
  5. Enter the name of the user in the [Name] box, and the name to display in the [Key Display] box on the control panel of the device. Here, we have entered the name Sam User and the key display name S.User.
    If you want to enter titles, select them from the [Title] boxes.
    (Titles can be used to divide users into logical groups. Title 1 is alphabetical from AB to XYZ, Title 2 is numerical from 1 to 9, and Title 3 is numerical from 1 to 5.)
    Next, click [OK].
  6. Enter their e-mail address in the [E-mail Address] box, and then click [OK]. Here, we have entered [email protected] as an example.
  7. On the [Edit] menu, click [Apply Settings].
  8. When the message Are you sure you want to apply settings to the device? is displayed, click [Yes].
  9. On the [File] menu, click [Exit].
  10. On the [Group] menu, click [Exit].
Pinnacle Studio Plus version 10 Keeps Crashing
If you are getting any type of error message or warning message (except a fatal crash message), then , click here to see the FAQ titled "Studio Launch error/warning messages" to resolve these issues. For a fatal crash or any type of lockup/freezing while launching, continue with this FAQ, below.
If Studio was launching for some period of time and then it stopped launching, it is best to try to determine what changes have been made to the computer recently and undo the changes to see if it has an affect on the problem. Here's a short list of what could affect Studio's ability to launch:
  • A Studio patch was applied but it didn't install properly
  • The graphics driver was updated
  • Hardware was installed
We recommend using Windows XP System Restore. You can obtain more information on how System Restore works from the Microsoft web site at:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Troubleshooting steps for Studio hangs or crashing while launching (starting)
1. RESTART THE COMPUTER. Try restarting the computer
2. WAIT A FEW MINUTES: If Studio still won't launch, wait a few minutes to let it finish launching. We have noticed on some computers that it may take a little while for Studio to completely launch. Studio 10 users click here to see the FAQ on this.
3. LATEST VERSION OF STUDIO. There was a launch problems in previous versions of Studio 10 that are now fixed in the latest version. When troubleshooting any problem, it is always best to be on the latest version of the software.
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
If you have Studio version 10, download the latest version here .
Note: Studio 11 patches will only patch a previous install of Studio 11. Studio 10 patches will only patch a previous install of Studio 10. Etc.
If you have an older version of Studio (Studio 9 or 10, etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
4. SAFE MODE: Try launching Studio in Safe mode. In Safe mode, many device drivers and applications do not load. If Studio will launch in safe mode, then the issue is most likely a configuration problem with your computer. NOTE: We do not recommend using Studio in Safe Mode. This step is for testing purposes only. To start in Safe mode:
  • Shut down the computer
  • When you turn it back on, tap the F8 key every couple seconds until a menu pops up. (If the XP splash screen appears, the F8 keys was pressed too late so restart the computer and try this step again)
  • On the menu, choose Safe Mode, and then press the Enter key
  • Launch Studio
If you need help starting in Safe mode, you can click here to get information on Microsoft's web site
If Studio won't launch in Safe mode, then Studio many not be installed properly or the install may be corrupt. We recommend uninstalling and reinstalling Studio.
Click here to see the FAQ on how to uninstall, then reinstall Studio 10.
2answers
Games
seems like your graphics card is weak, anyway,again try deleting the driver and ati products then download and install latest driver from ati's website. Hope this helps.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
