The plate inside is no longer turning. I am sure it is positioned correctly. There was no warning, it just quit turnng.
Hi, It could be one of three things.
The first and easiest to check is the coupling. Pull the plate off and under it, in the center of the oven is a small plastic piece that drives the plate. This coupling will pull straight up. Look to see if it split down the stem, if it is broken that needs replaced. If it is okay then we have one of two issues, both requiring you to disassemble the microwave and take meter readings. Do you have the ability and access to a good ohmmeter?
Replacement of the
turntable motor should be carried out by a qualified appliance repair
service.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
But here is a basic method if you are
mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is
not split or broken and causing the problem.
The motor assembly is fixed to the base
of the oven usually with two screws and access is obtained usually by
removing the inspection plate directly beneath the motor. It is
usually a plug in synchronous motor that revolves at a few revs per
minute but the plastic cogs in the motors gear box fail and the motor
assembly must be replaced. They are fairly inexpensive and obtainable
usually from a domestic appliance repair shop.
If you feel
confident, disconnect it from the mains power, remove anything in the
cavity and turn it upside down if it is a tabletop model, a little
more complicated if it is built in!
Remove the inspection plate,
sometimes it must be cut out with sharp cutters, and disconnect the
motor. Remove the motor and go and get a new one. Fit the new motor
and fit the inspection cover back on the base by turning it to fit
and using an extra screw fix it then put the microwave back in its
position. Plug it back in, with the turntable and plate. Put a cup of
water on the plate inside of the oven and heat for 20 seconds to
check the plate goes round.
Hope this helps.
Replacement of the
service.
YOUR
Attempt
If you feel
Hope this helps.
It doesn't appear to be split but it still doesn't work. I don't have the ability or access to anything
