Question about Whirlpool Microwave Ovens
Phillips microwave oven vt255/bl tuntable does not rotate
Posted by barry hartley on
washington foronda
    New Friend:
  • 19 Answers
Gear box motor broken, replace it..
Posted on Aug 19, 2014
ADEREMI RUFAI
    Novelist:
    Scholar:
  • 65 Answers
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Posted on Oct 01, 2011
  • David Green
    David Green Mar 03, 2014
    The turntable has never stayed in place from new. he depressed section has shallow sides, easy for the wheeled ring to ride up and out.
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
How do you change fan exhaust from wall to front of unit.thanks
physically pull up and rotate exhaust blower fan assembly so it points toward the front. you'll need to remove a plate with a common phillips screwdriver.
Aug 06, 2011 | Goldstar MV-1501 Microwave Oven
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Plate will not move back and forward
That is either tuntable motor or turntable motor coupler, depending if the motor is working or not. If the turntable is stuck it is more likely the coupler located underneath the plate.
Apr 20, 2009 | LG Over-the-Range Microwave
Ge spacesaver turntable will not turn
my mocrowave turntable will not turn but it will heat up.
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG over the stove model lmvm 1935
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
In some cases, cleaning them helps. Lubrication is not recommended.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
Microwave problem turntable spinning after replacing door switches
Make sure the switches are connected EXACTLY as the original ones, maybe one was connected incorrectly. It also can be the controller board.
Feb 16, 2008 | Whirlpool MH2155XPS Microwave Oven
Microwave Ovens Logo
615 people viewed this question
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
