The Control Locked light is on and the washer will not respond to anhy command. We have tried to push any combination of buttons, lloked on the back of the machine for a reset button and even unplugged the machine and tried plugged it back in in order to attempt a reset. nothing has worked.
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool
Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum -
Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai
Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
