SOURCE: Child Lock Problem
Press and hold the TV/AV button and then press the red on/off button, the TV screen will become black, and any buttons on the main unit or the remote control become inoperative. If you want to switch on the TV, press and hold the TV/AV button and then press the ON/OFF button again, the TV will return to the normal TV reception
SOURCE: Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
SOURCE: my tv is a tcl brand model tcl-14175 i
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
SOURCE: My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Locate
it.
Try
child lock code.
Instructions
Locate
it.
Try
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
