When you press the power button u hear the click but it does not comes on .The filament on the CRT neck does not light neither. it is an RCA television...model no. MR27035
If tv is a few years old could be power supply capacitors faulty, sometimes the tv could come on after a while , had this problem on friends tv, Only cure would be replace capacitors, not a job for novice though. pete
Hello, If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board. Hope this will help...
If the picture faded away on the order of 10-20 seconds (and if it comes back, also comes up to full brightness in same time frame - possibly with the persuasion of some careful whacking) AND with NO other significant changes such as size, focus, etc., then take a look in the back of the tube for the filament to be lit - the orange glow near the CRT socket. If there is none, then you probably have a bad solder connection on the circuit board on the neck of the CRT. Look for fine cracks around pins on that board. Try prodding it with an insulating stick to see if the picture comes back. Resolder if necessary. Dirty or corroded CRT pins/socket contacts can also do this - remove, inspect, clean, and replace the neck board. It is probably not a bad CRT as the filaments are usually wired in parallel and all would not likely go bad at the same time.
However, if only a single color fades in and out, then a bad connection inside the CRT is a distinct possibility - look for only one of the filament's glow to be coming and going. This is probably not worth fixing.
If the picture faded away with other symptoms, then there is probably a fault in the video amplifier/output one of its power supplies - still probably a loose connection if you are able to get it back by whacking. Good luck
Most projections have a removable speaker cover on the front under the screen. Then there is an access panel that you remove the CRT sockets are the circuit boards attached to the CRTs
Can you be more specific
