Linksys EtherFast Cable/DSL Router Logo
Posted on Apr 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I connect to the internet via ATT DSL I get a white homepage without what I have selected to be on my homepage I am the only one who uses it . Why can't I save the color and info that I have selected so when I go online again it will open to the color and info that I have selected. I have the remain logged in for 2 weeks checked.
Anonymous
Level 3:
  • Master 1,768 Answers
  • Posted on Apr 29, 2010
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528702
Points
5915
The router page cannot be changed/ You change the home page feature in "options" under the "tools" tab/
the manufacturers GUI is set in the router.
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
My 2 wire modem is acting has the ether net and the wireless constantly blinking, and the dsl and internet cannot seem to stay on green at all. I am having a troublesome time because I am trying to do my...
ATT is your high speed internet provider and they supply you with 2wire DSL modem which has alot of power supply adapter going bad (you can Google 2wire AC dapter problem).
You can buy your own DSL modem but the key is the setting it up, it depends on how your ATT DSL system is setup, DHCP, PPOe, etc. What ever you do I hope you do have the user name and password that you may need to setup the new modem.
To explain exactly how here will take many many words and pages to explain, and without knowing your exact setup, it will be real difficult.
ATT does not care if you use your own DSL modem but they will not help you setting it up.
I would suggest you to get someone at school that knows a lot about computer, may be aks your school IT person to see if he/she can help you for free pizza.
I hope my explanation will help you out.
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
I got a compaq evo d510 refurbished and I have ATT extreem internet service and 2 wire router conected to comp with erthnet cable, It will not connect after installing att cd. It keeps trying to use dial...
Since you are using the Internet I must assume you are using the Dial up settings. I may expect that this AT&T service is DSL. In Internet Settings there is a tab marked "Connections" and the Dial Up settings are set to "Always Dial My Default Connection". Click on "Never Dial a Connection" and this problem should be solved. Next thing is to ensure that the DSL connection is connected properly since if this is not setup correctly you won't even get online until you reset the "Connections" tab to the original setting.
2helpful
I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
1helpful
Mms setting for att
Internet settings for AT&T
Title:
Att
Bearer: GPRS
Auth: PAP
User: [email protected] (all caps)
Password: CINGULAR1 (ALL UPPERCASE)
APN: wap.cingular
Browser>Settings>Profiles: (Internet Setting)
Service Name: Media Net
Homepage: http://www.google.com
Connection mode: TCP without proxy
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Messaging>Settings>MMS>MMS center: (MMS setting)
Title: ATT MMS
MMSC URL: http://mmsc.cingular.com/
Connection Mode: TCP with Proxy
Access point: ATT
To get google and all your other java web access make sure that this is the only profile you have in the Access Point. This will default as your java web setting & streaming setting. So you can now stream youtube & use Opera Mini 4.
Best regard:
Henk®Muskita ©2009.
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Need help with my lg shine ke970
Set the homepage to: http://device.home
Set the Bearer: GPRS
GPRS settings:
APN: wap.cingular
User ID: [email protected]
Password: CINGULAR1
1. Scroll to and select Proxy Settings and press OK.
* IP Address: 66.209.11.32
* Port Number: 80
2. Press the End call key to return to the standby screen
I found this on the web, its a little different then how I did mine, so here it is in case mine doesn't work for you:
here you go...it works !!!
Phone Setting>Connectivity>Access Point: (Data Setting)
Title: Att
Bearer: GPRS
Auth: PAP
APN: wap.cingular
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Title: ATT MMS
Access point: ATT
1helpful
3answers
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
