Car CD Players get dusty from road grime. Buy a CD Cleaning Disc and run it is a couple of times. The laser that reads the tracks is much lower power, and if it can't read the whole tracking system, it ejects the CD. The cleaning disc has little brushes that cleans the optic lenses.
It tries but can't read the disc, then it ejects it. If CD player plays other discs OK, then it is the disc. If it won't play anything there is a problem with the CD player.
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And
Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be
Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this
CD player. The labels may warp or wrinkle and jam the CD player
mechanism. Refer to the Compact Disc Care and Cleaning procedure
(Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to
reset the radio and then eject the CD(s). If cycling the power to the
radio does not allow the CD(s) to be removed, the radio may have another
failure that will not be corrected by the reprogramming procedure that
follows. Refer to the Diagnostic Starting Point - Entertainment
procedure in SI to begin your diagnosis of this failure to eject CDs
concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with
the latest software available on TIS2WEB. Refer to the SPS procedures
and the Radio Programming and Set procedure in SI for more information.
As always make sure your Tech 2® is updated with the latest software
version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
try another cd wont play if too scratched or dirty. handle disc by edge, dont touch the surface of disc no matter how lightly you hold it, you will leave contaminants that cloud the surface. if none ever work try them in a house cd player still no joy, then discs aare no good, if they work in home player then car cd died, time for new one. heck who uses cd any more? its a hassle to change them (only 16 songs!), hassle to replace lost daamaged or stolen(borrowed by friends), skip or scratches, get a radio with usb reader/player or SD card reader, can be had for under $60 , an 8gb SD card for $25 (4,000 songs<do you even KNOW the names of that many songs?) PLus, without a cd slot the thieves should leave your radio alone, thinking its just a normal am/fm radio. goto www.dealextreme.com for great deals and FREE SHIPPING.
you may have to use needle nose pliers to pull them out or remove the radio and open it up and remove them also take a look at the drive belt it may have broke, there are many electrionic places that will repair it if you remove it and take it to them, most of the one i run into broke a belt or 2cds were jamed inside it.
you need to use cd-r + look at the ones that don't work they are cd-r- you might of also not closed out the disk that would keep the disk where it would work on you pc but not your cd player.
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix thisissue or, you can just purchase a new changer and save a lot of money.
