Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
