How do I connect my Dell Inspiron E1705 laptop to a Panasonic PT-AE900U and a Harmon Kardon AVR435 receiver?
Thanks!
**I have an HDMI to DVI cable. The projector has the HDMI input.**
"the PT-AE900U supports a full range of input sources,
including DVD and video players, PCs and game machines. An HDMI input
provides compatibility with HD digital sources, while component video
input terminals deliver full-quality, detailed images from high-end,
progressive-scan DVD players. The PC IN terminal can be connected to a
game machine or PC. Other terminals include composite and S-video, as
well as a serial terminal for connecting a touch panel controller or
similar device." You can go to Dell support to either read your manual, but your laptop model's manual is there for the reading. It lists all the outputs. if you have a problem figuring which to use, they will tell you. your manual can be found at http://support.dell.com/support/dsn/dsnsearchresult.aspx?c=us&cs=19&l=en&s=dhs&Query=bWFudWFs&SystemID=INS_PNT_P4_9400&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1
You may either have to connect the laptop directly to the Panasonic, or you may be able to connect it through the Harmon Kardon, but I doubt if there will be any advantage to doing that.
Hi, I need to connect my dell laptop inspiron 14r to a viewsonic projector pjd 6211.
The laptop does not have a VGA port. It has Hdmi, Rj45 port, and usb 2.0 and 3.0. Is there any adapter o
