20 Most Recent Panasonic PT-AE900U Multimedia Projector Questions & Answers
Well here is a partial solution. Turn off Dynamic Iris and the noise will go away. Now could someone tell me how to fix the Dynamic Iris?
Panasonic... | Answered on May 22, 2019
in side the projector is a small like an lcd screen i cannot remember the name, but they are not cheap this is how the projector displays the output so you can see the screen programs, this would of gone they do this, over time, this would need replacing, they are not cheap but you can replace it. its at the end of the light chamber in between the lenses. the part is called DMD
Panasonic... | Answered on Jul 08, 2017
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Panasonic... | Answered on Apr 14, 2016
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Panasonic... | Answered on Apr 09, 2016
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Panasonic... | Answered on Sep 03, 2015
Hello , the problem is usually the Power Board . Requiring a technician to fix it
Panasonic... | Answered on Oct 14, 2014
To me itcsounds like ypu have a 1080p signal, 1080i is what it accepts. The 1080p signal will only show up on half the screen. Switch blue ray player to 720p or 1080i output.
Panasonic... | Answered on Aug 19, 2014
the projector flickers after 10 minutes ,it seems that the lamp ballast is failing
shows with vertical lines, it seems that the LCD panels are failing or the panels cable not be tightly plugged (panel-cable plugs into the mother board)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Panasonic... | Answered on Mar 18, 2014
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Panasonic... | Answered on Mar 13, 2014
Check the Panel ribbon cables and re install
Panasonic... | Answered on Jan 17, 2014
Check Panasonic's website service department for the cost and availability on the replacement fan.
Panasonic... | Answered on Jan 12, 2014
Refer to the page 43 of its manual.
You can download it from the following URL.
ftp://ftp.panasonic.com/pub/Panasonic/business/projectors/manuals/PTAE900U-MULTI.PDF
Panasonic... | Answered on May 13, 2013
If you are handy with SMT rework it might be possible to fix this problem. The heat spreaders on the LCD drivers are insufficient to cool the chips and they will get hot enough to reflow the solder and cause a short on some of the pins. I think it most often happens after bulb replacement since bulbs near their end of life are dimmed and run cooler. After replacing the bulb the bit of extra heat is all that is needed to push them over the edge.
The problem also seems to be most prevalent on the green IC since it shares a heatsink with red and has a smaller area to dissapate the heat into.
If you pull the heatsink you will probably be able to see the short with careful inspection. The pitch is very small - 0.6mm but I was able to wick, clean, and reflow one side of my green IC and the problem went away.
I am planning on adding some additional aluminum stock to the heat spreaders with some thermal adhesive to give the chips more cooling.
By the way the very common rattle noise in these projectors is not a fan but the auto iris. You can unplug the iris servo from the mainboard and disable the auto iris in the menu to work around the problem or you can replace the iris servo for about $75, again, if you are handy with that sort of thing.
Panasonic... | Answered on Mar 31, 2013
Something is catching on the fan blades. Possibly a screw or piece of plastic has come loose and is connecting with the fan blades when you switch it on. When the projector has been cool for a few hours remove the lamp and gently shake the unit to dislodge whatever is catching on the fan.
Panasonic... | Answered on Mar 13, 2013
Panasonic PT-AE900U Multimedia Projector Logo
103 questions posted
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
pt ae900u wont turn
  • Office Equipment & Supplies
