Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
1. Turn off your copier
4. Repeate the above step for all buttons that you can find to access the inside of the copier
6. Turn on your copier
Step 1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2. Turn off the printer.
Step 3. Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step 8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Also open the back cover of the printer if this model has one.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
printer back on.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
printer back on.
alternative :
Load
printer back on.
alternative :
Load
Step1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step 2 Turn off the printer. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step 6 If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step 7 If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
printer back on.
alternative :
Load
printer back on.
alternative :
Load
