Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Mar 13, 2010
No sound on new 55" flat screen w/ built in speaker system
No sound on new 55" Had sound but not now...what should i check
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
677
Points
6
Chack sount if that is decrese plzzz sound up ....after it ll't done .....plzzz chack from macanic
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
1helpful
Audio seems weak...how to increase volume
this is gotta be the largest complaint I hear from folks when they get a new flat screen , its not loud enough or the sound sounds muffled
flat screens are flat ! so theres no good way for mfg to put the speakers facing forward so sound has to hit the wall behind it first then gets directed forward to you ! (low/muffled)
sound bars help with this , but for true rich sound , id go with a video receiver amp combo , some of these even have built in dvd players , and arrange its speakers in a forward facing direction
1helpful
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
No sound from inbuilt speakers or is the speakers built in?None came in the box!
Hi:
Sorry to bring this up to you but your LG flat screen does not have built in speakers.
have a great day>
1helpful
Isnt there built in speakers? or does it have to be hooked to a stero system? i never had a flat screen before and just inherited this,without a manual, but have remote at least. picture is great and pic...
Hello; This model does have built in speakers just below the screen. If you don't have sound, make sure the sound is not muted and that SAP has not been selected in the audio mode on the remote control. Read/ download the owner's manual for best info. If still no audio, you have a failed circuit board. John
I have no sound on my Vizio 55" hdtv
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
1helpful
Warning label on screen
It sounds like a 'mute' icon. Check for a corresponding button on your remote control.
Just to clarify - You say the TV sound is fine but you do not use the built-in speakers...
Can you actually get any sound out of the TV speakers? If you can't it is because the TV is on mute (For your type of setup you will need to turn it off mute and then just turn the volume all the way down.)
If you can get sound out of the built-in speakers and the icon is still showing, it is almost certainly going to be a fault with the TV. You could try unplugging it, leaving it for a minute or two and then plugging it back it. This may well reset it.
Hope this helps!
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
2answers
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
