my denon avr-210 6 suddenly started switcing off each time i switch it on (it switches off automaticaly af afterter about 5 seconds) when its off, the power/standby switch flashes red while its on (for 5 seconds) the power/standy switch flashes green untill it switches off please help
The flashing light indicates that it detected overheat. Too much power could be one possible cause as tdrose hinted.
Mine was the same but the problem went away after 2-3 weeks. Looks like a burn-in issue for me.
When the standby light flashed, I switched off the mains with the little knob next to it and waited a minute or two to let it cool down. then I turned it back on again and the uptime woudl be longer than before. After off/on for 2 or 3 times it would last the whole day. After 2-3 weeks the prob went away altogether.
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
My Denon shuts off after being on for 5 seconds. Then the power button flashes red.
receiver keeps shutting off
I have the same problem
I have the same problem.
sounds like we all have the same problem... does anyone have answers for us?
I have that same problem too!
I have the same problem as well.
I have the same problem, but nothing is hooked up to the receiver.
Denon AVR-2106 no audio
I have a similar problem with 3 years old AVR... Upon turning unit off one day, there was amoderate pop sound from all 5 speakers and power light flashed red butdid not shut off. I shut off. Now when I turn on again, there will beseveral seconds of flashing green, then a very slight power relayclick-on sound, but no sound any more. To provide 'more details'requires opening the box. SOmeone mentioned a thermal fuse, can I pull itand exchange it? Thanks... Mike
