The most common issue that could cause a lack of beep on startup is RAM related issues. Try removing and dusting the inside of the computer with compressed air. (Obviously, make sure that the computer is unplugged from the electric socket) As always, touch a metal surface before touching any of your inner computer components to dissapate static that can damage your components. After cleaning, remove the RAM and then reseat it in the motherboard RAM slots. You will have to apply slight pressure to reseat the RAM, so make sure that you push evenly on both sides of the RAM to prevent damage to the mother board. If this does not work, the problem may lie with one of the other components.
If there are not lights on the motherboard or case at all when you push the power button, the issue may be the PSU (Power Supply Unit)...
