Control Panel / Sound / Playback - Adjust System Volume.
If you want the icon: right click on the Taskbar / Properties / Notification Area / System Icons list tick Volume.
right click on speaker icon, select play back devices, a box will appear and show the devices that are present, if there is more than one, click on the one that has no green check mark on it. Click set as default and try again. Also make sure nothing is muted.
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer. Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel. Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel. Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Click "OK" and close the Control Panel. Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Click "OK" and close the Control Panel. Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Click "OK" and close the Control Panel. Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Which operating system ? Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume in XP
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section 1. Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3.
Verify the "Place volume icon in the taskbar" checkbox is checked.
If this option is not available or is grayed out, skip to the next
section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check
Windows services. Right Click My Computer and Manage. Choose Services
and Application
This problem is due to some virus attack on to your computer...Scan through antivirus
or
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the
above patch solution and the following windows update solution works
only on PC/computer running genuine Windows and not pirated versions):
Go to the start menu
Right click “My computer”
Click “properties” then the “automatic updates” tab
Choose “turn off automatic updates”
Restart your computer
Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
Manually update windows
Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
Go to Run and type regedit
Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >>
CurrentControlSet >> Services >> Browser >>
Parameter
click on start,goto controlpanel,you will see a speaker diagram click on it to increase the volum.but if it is blunt you have to contact your IT person to install the driver you need
