20 Most Recent Sony VAIO FX150K Notebook Questions & Answers
there might be some problems and you have to go through them.
--> check the cable
--> check the vpn connection settings
--> check the server name
--> check the user name and password (it should be same as of your system in office
--> make sure your computer is on at work
i hope this will help you
if none of them work then the easy way is to make other connection that will definitly do
Sony VAIO FX150K... | Answered on May 18, 2018
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Sony VAIO FX150K... | Answered on May 25, 2014
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Sony VAIO FX150K... | Answered on Apr 15, 2014
Instructions
    • 1 Open the Vaio screen until you can easily access the keyboard.
    • 2 Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers.
    • 3 Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer.
    • 4 Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side.
    • 5 Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard.
    • 6 Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart.
Sony VAIO FX150K... | Answered on Jan 12, 2014
Bat 1 is positive and Bat 2 is negative.
Chris
Sony VAIO FX150K... | Answered on Aug 12, 2011
what happen to my PC when i turn on " VGC LS1" got white screen but i still can hear the Windows run normal?? Help Please!! thanks
Sony VAIO FX150K... | Answered on Jan 26, 2011
use http://www.pcloginnow.com/product.html this will remove your windows passwords, download on another pc and burn to disk, then use on boot up on your laptop.
Sony VAIO FX150K... | Answered on Oct 05, 2010
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sony VAIO FX150K... | Answered on Sep 21, 2010
when adding new memory always take all memory out, reinsert the new 256mb stick into the first memory socket dimm1 normally, boot the laptop up, if the laptop boots then fine the memory module is ok, shut down and insert the original 256mb into the second slot, dimm2 then boot the laptop it should now boot normally, if not there maybe problems with the memory slot itself, give it blow to get rid of any dust and try again, if this dosent work post back.
Sony VAIO FX150K... | Answered on Aug 20, 2010
Yes the cmos battery is on the motherboard.
Every motherboard that runs a computer has a backup battery to run the circuit while turned off. This battery runs the real-time clock (RTC) and is referred to as the CMOS battery. By keeping the clock active and running even when the computer is switched off, power up/down cycles can be logged and before the internet, your computer could keep dates accurately. It also serves to maintain the system configuration settings in BIOS memory based on RAM or FLASH RAM.
Sony VAIO FX150K... | Answered on Jun 25, 2010
here's the manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCGFX150
Sony VAIO FX150K... | Answered on Apr 09, 2010
at the back there would a white strip containing some info. it would be sticked on battery . there would be 2 buttons. first slide lock and then slide release and its done
Sony VAIO FX150K... | Answered on Oct 30, 2009
Sony VAIO FX150K Notebook Logo
Popular Tags
33 questions posted
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
cmos battery holder detached
  • Computers & Internet
