Computers & Internet Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp dv4000 caps lock and scroll lk lights are blinking but the labtop wont come on, what do i do?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 81 Answers
  • Posted on Feb 21, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
81
Questions
0
Helped
21404
Points
203
First take the battery out and disconnect all the cables from the sys and remove any accesories connect and press and hold the power button for 30 to 40 seconds. Insert the battery and power cord and try turning the sys on and keep tapping the F10 key to go to the BIOS screen. If the system boots to the BIOS screen than hit the F9 key to set BIOS defaults and turn on the sys, if the sys doesnt turn on than disconnect everything along with the battery. You will have to open the back of the sys and take the RAM and harddrive out and reinsert them back into the sys and than try to turn on the sys after the RAM and HDD is put back. If this time the sys doesnt turn on than the motherboard has gone bad, you will have to get it repaired.
Anonymous
Level 1:
  • Contributor 1 Answer
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
914
Points
Www.hplies.com
This might be same problem as happens with the dv2000 and dv600 series, ie a faulty nvidia graphics chip on the mainboard, you might qualify for a free recall/repair from HP....good luck on that....
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
The problem is...i have a ...black screen, the caps and scroll lock blink 4 times and continues this reading over and over again.
remove your battery and return after 1 minute. and turn it on. same problem check your memory ram.
2helpful
2answers
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
try to boot in f12 format then run windows after prompt.
1helpful
The little lights by the caps lock and scroll/number lock are flashing...I know that if you restart your computer it will stop for awhile, but how can you fix it permanently?
hi colleensousa, to fix it permanently try these steps:
Turn off the pc
remove the cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert the cables and battery on the pc
Turn on the pc
check the caps and num lock if they are continuously flashing on your laptop...
Hp pavilion dv4000 screen wont turn on
Try this quick fix first. Remove the battery, unplug the ac adapter and hold in the power button, plug the ac adapter back in and turn on.
7helpful
2answers
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
