If you're getting this error, it means your registry might be corrupted. Try the following:
Click Start and then click All Programs.
Click Accessories, and then click Run.
Type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters. On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters. On the Edit menu, click Delete.
Exit Registry Editor.
Restart the computer.
If it does not work, uninstall and reinstall the drivers by:
Click Start and then click Control Panel.
Click System and Maintenance, click System, and then click Device Manager.
In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
When you are prompted to confirm that you want to remove the device, click OK.
Click Start
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the CD/DVD branch of the tree.
Right-mouse click on the CD-ROM, and choose "uninstall" or "remove".
Restart your computer, and Windows should "find new hardware", and should load the correct device-drivers for your CD-ROM.
To run a dvd on windows media player you need the corect codec, it is better to use "power dvd" or somethign to watch dvds. For the cd drive not working, this error code means it is not been reconized. Try doing the following. goto control panel and system, then goto device manager, uninstall the cdrom drivers and restart pc, maybe this will clear the conflict. Here is also a link to a fix programme by microsoft that will try fix your cdrom for you. click here
follow the instrsuctions and it will clear your regsteries and all for you, hope this helps
Please roll back your driver or you need to reinstall driver from driver CD i think this is helpful to you if this solution is not solve your problem then plug out your CD ROM and replug CD ROM properly
Error Code 19 means that the registry is corrupted. Try the following fix:
If this does not work, try uninstalling and reinstalling the computer by:
Click System and Maintenance, click System, and then click Device Manager. In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
