Toshiba Satellite A40-S270 Notebook Logo
Posted on Feb 12, 2010
Toshiba satellite a40-s270 won't turn on
Toshiba satellite a40-s270 wont turn on - battery charge light blinking yellow regardless if charger is in or not.
David Lee
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Feb 12, 2010
David Lee
Contributor
Level 1:
New Friend:
Answers
29
Questions
Helped
6426
Points
75
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
I started charging my toshiba satellite M15-S405 laptop with a universal charger, IGO ac power adapter,with a #702 head/tip, that i bought from wal-mart, and its been having a yellow blinking lite in front...
Disconnect the adaptor and remove the battery from your notebook. Then connect the power adaptor and see if it boots up. If it powers up OK now you may have a bad battery. If the notebook still will not power up, the adaptor may not be compatible or there may be a different hardware problem.
Locked bios dont have password
Try removing the battery out of the motherboard. This will be a small watch battery, not the main laptop battery. If this doesnt work, try grabbing the motherboard manual, there could also be a jumper you need to connect to reset.
Toshiba satellite a40 s270
Boot from DVD with recovery disk in the drive. Select Restore and follow the prompts.
1helpful
2answers
Wheres the ram?
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
1helpful
Dont know how to change ram in the toshiba satellite pro A40
Flip it over and loosen 2 screws holding a panel in the center of the laptop.
Once door is removed, it will expose ram modules.
pry locking tabs out, and module will spring UP. remove, and replace reverse of removal.
Keyboard beep
Isolate the issue first. If your using an external keyboard, remove it and test if you still experience it. If not, then there could be a stuck key on your external keyboard.
If yes, then there could be a stuck key on the laptops keyboard.
If there is a stuck key, try to check the buttons on the KB then contact Toshiba to avail of your warranty for the repair.
Hope this helps.
1helpful
2answers
1helpful
3answers
Toshiba satellite M30 wont power up...
you are using the wrong charger which is damging the battery or the battery is fulty
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
