20 Most Recent Toshiba Satellite M30-S350 Notebook Questions & Answers
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Toshiba... | Answered on Jan 31, 2013
The screen should tell witch F key to press while booting. Watch for it and restart. It should be something like F2, F9, F10 and so on.
Toshiba... | Answered on Aug 30, 2012
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Toshiba... | Answered on May 05, 2011
More likely you will have to tear down the laptop to get to the CPU fan. If you have never torn apart a laptop I suggest you take it to a local repair shop.
Toshiba... | Answered on Feb 25, 2011
You may have a faulty ballast unit. They are fairly cheap on ebay and easy to fit. Just unscrew the four screws holding the bezel on to the screen and it is there, under the screen.
Hope that helps.
Toshiba... | Answered on Feb 06, 2011
  1. Go to NVIDIA Gforce web site, select your product, download the latest driver. Upgrade the old driver. Restart your PC.
  2. If still not working, remove the Graphics card, clean properly and reinstall.
  3. Go to device manager check harware performance.
Toshiba... | Answered on Aug 20, 2010
May be its system files got corrupted. Make sure you've enabled the boot up from hard drive and make it first in the boot options.
If you need to know how to install from XP boot up CD, here is the link : http://pcsupport.about.com/od/tipstricks/ht/bootcddvd.htm
Hope it worked. Thanks and All the best.
Toshiba... | Answered on Apr 21, 2010
either google it or go here...
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Toshiba... | Answered on Jan 25, 2009
ok, a modem on COM8 ? Normally modems are on COM1, COM3. You need to fix that problem first. Most softwares are not setup to scan that high for the modem. (ps: COM2, COM4 are usually for other devices - in the old days, mice were on COM2). Follow instructions:
START
CONTROL PANEL
PHONE/MODEMS
Click over to MODEMS
Click on Proper MODEM
PROPERTIES
ADVANCED
ADVANCED MODEM SETTINGS
Change COM8 port to COM3
click OK, probably going to have to restart computer.
Let's see if this actually solves the issue. if it did not and you need more help, contact me through this site and we will proceed forward.
Toshiba... | Answered on Jan 15, 2009
replace the battery replace the adapter and all will be find..
Toshiba... | Answered on Sep 25, 2007
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Toshiba... | Answered on Sep 16, 2007
you are using the wrong charger which is damging the battery or the battery is fulty
Toshiba... | Answered on Aug 17, 2007
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
Toshiba Satellite M30-S350 Notebook Logo
Popular Tags
27 questions posted
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite m30 bios password
  • Computers & Internet
