Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Are you trying to connect to the wireless network on the laptop ? It is very simple. first you will need to make sure that you have all the wireless settings of the network. Click Here for more info about wireless network connections
1. First you need to configure your router with your laptop wired or physically connected to it.
2. Connect your modem to router's WAN/Internet port. Then your laptop will be connected to the one of the router's Ethernet port using an RJ45 or Ethernet cable.
3. You may run the setup cd that came with the router. Configure it with the Internet connection type that Bell Sympatico requires.
4. The setup cd will also require you to set up wireless in the router. Once it is done, disconnect your computer from the router.
5. Enable wifi in your laptop and select the wireless network that you set up and connect to it.
You will need to connect your laptop to an ethernet connection to get on the internet so that you can download the drivers for your MIMO USB ADAPTER. You can also download the file on another computer and use a flash drive or burn a CD to transfer the files to your laptop.
hi.
plz pos the error msg your are getting
cheer!!!
