Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
SOURCE: i lost my lynksis befw11s4 router star up disc what can i do
Hi, There are 5
versions of this model. The drivers for your LinkSys BEFW11S4 Router are
available here.
You have to select which version you have and can be found at the sticker
underneath the router. Good luck
and kind regards.
SOURCE: Cisco and Lynksis Routers
Hi, you don't have to send it to me. I can help you with that. First we will check if the router is still working. Simply connect a computer to port 2 or 3 or 4 or 5, and lets see if the computer will get an ip address of 192.168.1.100, if it does there is a chance that this could work.
To checked ip address:
After connecting the pc to the befsr81, puss the reset button for 30seconds when the power is on, wait for 1 minute, reconnect the power. The power light of the befsr81 should be steady and the port light where you connected the pc should be lit.
Go to the computer. if pc is XP, click START then click RUN, in the open field type cmd then click ok, it will take you to the black screen. on the black screen type ipconfig, click enter. If the ip is 192.168.1.100 that means that we are in business.
I'l wait for your next post so i will have an idea on whaT IS GOING ON.
gOOD dAY
SOURCE: hi, i have a problem
You need to reconfigure your WAN settings of router to your new internet service provider settings.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router.
Click on WAN settings in general setup and set as your service provider settings.If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
