How do I remove a paper jam? The paper is sticking out of the bottom about 1-2". It will not pull back out?
I opened all treys and left side cover there is no paper peace. i used air blower but still the problem indicates first tray paper jam.
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
It may be this simple:
1- as silly as it may seem, are you sure the size is correct, if it is a letter size paper and it says legal, it will jam. open the paper tray and make sure the guides are snug againgst the paper,
does it say letter (or legal) for the tray you are going to use, if they do not correspond then look behind the tray inside the machine, is there a paper jammed in the back?
Or not so easy
2-You are having a sensor problem, take a look at the duplex tray,
pull it out and look at the sensors ( black little levers that stick out) are there any pieces of paper, can you move them and they spring back into place?
