Check to make sure the pump is not clogged. Just a small restriction can cause this and worst case scenario would be the Main control board. Easy to get to and check. Remove 3 screws at top of console and then pull main console assembly toward you and turn down to be able to see the board. Look for a blown resistor at the R-11 site. You should be able to see it pretty quickly if it is blown. If so replace board and wax motor. Good Luck.
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
