Some cameras need a driver to be detected, but some need the installation CD to detect the camera. You can use a card reader to have the computer detect the pictures, and drag and drop them from the card to the computer. The card reader will be detected in My Computer as another drive, i.e. f:, g:, etc.
Good luck and hope this helps.
You can try to use a different usb port of your computer check if it will be detected or try to plugged a different usb device see if it will be detected by the computer.If you have a different computer try to check if it will be detected. If the computer detects a different device it only means that the hard drive that you are connecting to the computer is faulty.
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Why doesn't my computer detect my sansa m240 it worked before i tried other usb ports that didn't work i tried going to my computer it didn't detect it again please help
Yes! That is, if you are certain that the device has no malware or virus on it! Shut the computer down completely (power off). Then connect your device and reboot the computer. It should then recognize your device.
First thing to do here is to try connecting the camera on a different USB port on the computer if its a tower connect the camera on the back USB port of it, if still not detected try connecting the camera on another computer and check if it will be detected , If still not detected the problem here can be with the USB cable that you're using so better try a different USB cable...
