Which slot are you refering to? dvd/cd drive, floppy, or something else?
Please describe in detail what slot it is that you want to turn on so that I can help you with your problem.
Sai.
Is the bus speed same for both of the RAM modules? Boot using both of the modules one after the other. Note the bus speed and then let me know. Also let me know the make and model of your motherboard.
Sai.
What does memory test say when only the second RAM is installed?
I mean when a RAM is installed into the second slot only?
Cable select affects only the Harddrive. The motherboard automatically determines whether it should be set to master or slave.
Sai.
I have been reading through your Motherboard's manual to see if indicates anything about turning on the slot.
http://downloadmirror.intel.com/15113/en...
Checkout page 69 for error messages and let me know if you notice any of the BEEP error messages and let me know your observations
Sai.
ALso let me know if you have any POST error codes when both of the DIMM modules are inserted.
Okay, I have a E- Machines T5048 and it has 2 slots for ram slot #0 and slot #1. I have 1 GB ram installed in slot 0 and the computer is too slow so I ordefred the correrct ram 1 GB ram stick and plugged it in slot # 1. I tried to reboot but it did not work. I tried the memory by it self in both slots 0 and 1 and both worked in slot o, but nothing worked in slot 1. Could slot one be turned off? Doing a serch on the internet, I was told to check my BIOS. IT is up to date. So, how do I confirm that the slot is bad or maybe just turned off.
OKay, I think I sent this to you Already but here it goes again. I have two slots where memory can be put in on the motherboard, slot #0 and slot #1. I purchased one additional stick of memory to help make my computer run faster and plugged it in slot 1 and the computer didn't boot up. So, I took out both sticks and tried them both individually in slots 0 and 1, and both worked in slot 0, but neither worked in slot 1.
Could slot 1 turned off some how?
Both run at 400 Mhz and system bus speed is 533 MHz
Motherboard is as follows:
product: D101GGC
VER: AAD54032-300
SER # : B7GC61600812
I had a thought, could there be a wire or plug that is not connected that would cause this problem. I had some hard drive issues about 1 month ago and disconnecting aand connecting it. The hard drive has the clip hooked on the CS position, should it be on master?
Both sticks do not work in slot # 1, the 2nd slot at all.....
OK, I do not hear any beeping when I plug a ram stick in slot #1. When I startup, the fans go at full speed but I get nothing on the monitor. Lookimg at the tower, I have a blinking light right where I connect mt internet card and also on the front panel under the on/off pushbutton. There are two lights about 1/8" diameter about 2" below the on/off. THis isd where the blinking light is going on aT THE FRONT PANEL.
Processor FSB is 533MHz, right? Ram memory typically operates at half the Processor's FSB. If you had an 800MHz FSB, you could use PC3200. 533MHz? Better use PC2700.
System bus speed is 533MHz? You should be using DDR Sdram at 333MHz. Read the Technical Product Specification for the Intel D101GGC motherboard, (Page 15)http://downloadmirror.intel.com/15113/en... (You may have gotten away with using one 400MHz stick, as it was clocked down to 333MHz. Won't do it for two 400MHz sticks)
