Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Uniden phone getting message from out of town to delete them once answered.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Nov 30, 2012
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444631
Points
622693
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual and the remote access instructions.
  • kakima Nov 30, 2012
4 Related Answers
Anonymous
  • 39 Answers
  • Posted on Mar 18, 2009
SOURCE: Uniden PowerMax5.8 GHz
Yes, it will automatically let you know when you have a voicemail. If it does not work, contact Comcast.
Anonymous
  • Posted on May 03, 2011
SOURCE: Can I retrieve deleted messages
Did anyone get back to you? I need to retrieve a deleted message. Thank you
Anonymous
  • 2047 Answers
  • Posted on Jul 09, 2011
SOURCE: I have a uniden 900MHZ
Sorry but messages deleted from an answering machine are usually not retrievable. Answering machines do not have backup memory for storing messages which get deleted unlike more complicated computer devices with extra space for deleted items. Sorry for any inconveniences.
Thank you for visiting Fixya. Hope this support has been helpful?
  • 102366 Answers
  • Posted on Oct 14, 2011
SOURCE: how do i get my
Since you didn't specify the model of your Uniden system, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to download a copy of the manual.
I have a 88 message on my uniden power max 5.8, model tru9480-3. can i get rid of that if the base is not in service.
Page 61 from the Base Unit, there is Delete All. From the handset you have to delete 1 at a time.
With.the.phone.in.standby, .press.[ ].to.
delete.all.messages..When.the.answering machine asks you to confirm, press [ ].delete again..All messages are.
permanently.deleted.
https://www.manualslib.com/manual/184807/Uniden-Tru9480-Series.html?page=61#manual
1helpful
My Uniden M/N:D1788-2 is not working correctly. It will only ring once before machine picks up & red light continues flashing.
Likely the two ring answer is "toll saver" You'll need to retrieve new messages. Once all new messages have been reviewed, it should return to the programmed number of rings, see "ring time" in the manual.
ALL messages may be deleted as follows;
delete all messages With the phone in standby, press Delete; press Delete again to confirm.
If answering system messages have been retrieved, a continuing flashing indicator could be your voice mail service;
Voice Message Notification • If you subscribe to a voice mail service, your phone can notify you when you have a new message. This feature supports Frequency-Shift Keying (FSK) notification. Contact your voice mail provider for information. • When you have new messages, the display shows a message icon. After you listen to your messages, the message icon turns off. If it doesn't, you can reset it. With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes
A copy of the manual is available from Uniden;
A copy of your manual can be downloaded free of charge from;
http://www.uniden.info/download/ompdf/D1788om.pdf
I don't know how to delete message on a uniden dect 6.0 digital answering system
Since you declined to specify the model of your Uniden DECT 6.0 answering machine, I can only suggest you select it from the list beginning here to download a copy of the manual.
How do I listen to and erase message?
Are you trying to get the messages from the phone directly or by calling into your phone.
If the answering system is on, then you can play back the messages from the base by pressing the Play/Stop button.To delete a message from the base, press the Delete button (has a 0 with a slash through it) while the message is playing. To delete all messages, press the Delete button when the phone is in standby. From the handset press the Messages softkey (has an envelope icon) when the phone is in standby. Then press Play/2 to play back the messages. To delete a message, press Delete/4 while it is playing. (Deleting all messages can only be done at the base.)
If you are calling into your phone system, you need to have set a two-digit PIN from either the base or the handset and remember it. Then call the number for your phone from a touch tone phone, press 0 and then the PIN within 2 seconds. (Do this while your greeting is playing or after a series of beeps when the phone answers your call after 10 rings if the answering system was off.) If the system is off, start by pressing 0 6 to turn it on. Press 0 2 to play back the messages. (All commands need to be entered within 15 seconds of the last command finishing with both keys pressed within 2 seconds.) To delete a message, press 0 4.
Uniden has the manuals for most of their phones on their support site: http://www.uniden.com/scat/cordlessphones_mnl . Phones are listed in numerical and alphabetical order; thus the TRU9480 manual is on page 7. The direct link to the TRU9480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9480om.pdf .
I hope this helps.
2answers
How do I check voicemail for a Uniden DECT 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
1helpful
Retrieve deleted messages from uniden cordless phone
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
7helpful
2answers
While the message is playing, click the top button, the one with the circle with a line thru it. That will delete the playing message. If you wish to delete all messages, click the top button when all messages have played, then click once again when the prompt says "delete all?"
I am out of town. Once I call my home phone and hear the address what number to I enter to hear my messages?
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual and the remote operation instructions.
1helpful
Message retrieval
Unfortunately, no, you can't get your messages back once you delete them. I've done it myself and I feel your pain, but that's how these phones work.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
