When you replaced the mobo did you clean the cpu fan if not check to make sure that the cpu is not getting hot and shutting down the board also a bad power adapter can also ad to your problem .bad memory from power arc will keep the system from starting let me know what happen. just so you know .when cleaning cpu fan stick a tooth pick in the fan to keep it from turning and spray with compresed air
It is highly unlikely that the it is your mobo since you saw the same problem. I would try to find another power supply before doing anything about the processor. Some times DC power supplies are defective either because can't handle the load(amperage pulls it down) or there is a breakdown where it lets through some of the AC component. You would need a oscilloscope to see the AC component. Just try to swap it out with another that has the same specs.
If it still gives you problems, the only thing left is the processor.
