All netgear routers have the same default user names and passwords, so unless you have changed it you should still be able to use the default one set by the manufacture.
IP address: 192.168.1.1
User name: admin
password: password
This is the default info for netgear.
If you are looking for your wireless password it will be found in wireless settings of the router on the admin page for your router.
Restoring a Netgear Router to Factory Default Settings
Symptoms: Cannot access the NETGEAR router or access point web interface login screen, or
You have forgotten/lost the password to log into the NETGEAR router or access point (NOTE : This refers to the password required to access the devices administrative interface. If you have forgotten the password required to access the wireless network, you should refer to this article instead).
The default password for the router's Web Configuration Manager is password. NETGEAR
recommends that you change this password to a more secure password.
To change the administrator password:
1. On the main menu, under Maintenance, select Set Password to display the Set Password
screen.
2. To change the password, first enter the old password, then enter the new password twice.
3. Click Apply.
Best of luck!
You can try resetting your netgear router to default settings. the reset is button located on the rear panel of your gateway to reset all settings to their factory defaults.
Here's the router default configurations settings:
User login URL: http://192.168.1.1 User name (case sensitive): admin or superuser Login Password (case sensitive): password
You can also check and download your router manual & user guides here:
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234). Note that you will lose the ISP settings and wireless settings when you reset the router.
