Magellan Maestro 4250 GPS Logo
Posted on Dec 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a tip for the car adaptor that goes over the fuse?
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Dec 21, 2009
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381066
Points
3221
Yes, there should be a tip over the fuse and also a spring. if your is missing and your charger was working, look inside where ever you had it plugged in last.
bill
2helpful
3answers
I have max displays md 219, 12v and I can't locate an ac adapter,Where I can buy one?
four things to consider while purchasing a replacement
1.voltage--we know its 12 volts DC
2.wattage-- your monitor uses 80 watts - this will take a ac adaptor with about 1 ampre
3. polarity of the adaptor- the inside tip of the adaptor cord needs to be the same polarity (posative or negative) as the plug it's going into. there should be a little insignia near where you plug the adaptor into the monitor with a partial circle and a line going to the middle of the circle, each having a plus or negative sign. the line that goes to the center is the inner cnnection (refered to as TIP)
4. size of the tip - dont accept any plugs that fit loosely as they will cause problems down the road.
If you have the old adaptor, you can carry it down to radio shack and they should be able to match it up for you. If not , print these specs and carry them in with you when you go----
here is the page showing the power specs available http://www.ciao.com/Max_Displays_MD_219__15408106#productdetail
1helpful
What fuse number for the diagnosis plug to get the check light engine
fuse number 24 is a 30 amp fuse goes to pcm relay and fuse number 30 the 30 amp fuse to ignition to pcm power diode.if check light is working your pcm has power but you could have short in the dlc connector terminal where you scanner adapter goes.your scanner suppose power up from the dlc terminal for obd 2 system the obd 1 you connect to cigarette light or use battery hook up cables that come with scanner make sure you are using correct adapter.
Is there an adaptor that goes between the
yes some taptop use adaptor and don't use adaptor.
2answers
1helpful
Cannot recharge using car recharger - no red light showing on charger plug in. Do not seem to have been supplied with a mains adaptor. Help Thanks Paul
Check the fuse in the car charger by unscrewing the tip - the red light should be on whenever it is supplied with power. Otherwise check your vehicle fuse to the 12 volt outlet (or try another device in the outlet).
Lost cigarette lighter adaptor
I purchased a replacement. Thank you.
The end of my 12 volt power supply cord was lost.
You might be able to use the parts from an old cell phone adaptor. Have you tried that?
If not don't mess with any off brand adaptor. Get another one from Garmin at their website Garmin .com
2answers
Targus laptop ac adaptor is not recognized by laptop all the time i have to wiggle connector for it to work
its not your ac adaptor its the connector in the laptop it eather has to be fixed or replaced
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
