First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size. Drivers Downloads
Any distortion in the picture of the LCD display points toward a defective display. It is possible there is a bad connection between the LCD flex cable and its connector on the printed circuit board but to to check it would require taking the unit apart.
Check your cable between the computer and the monitor, It may be a non-sensing cable which will be missing one of the pins so the monitor is not getting the correct data from the computer.
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
Wide- Display wide screen 16:9 broadcast in the correct proportions.
Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
To set up time.
Tap on main screen.
Tap on change preferences.
Tap on the arrow 5 times till you reach, Preferences 6 of 6 page.
Tap on set clock.
Select the way you want it to be displayed.
Click done.
You can correct the time on the next screen using the up and down arrows. When you have the correct time click done.
There may have been a software driver for your monitor for windows Vista to set the correct parameters - here’s what I found on Microsoft’s site but only for Windows 7
Have you tried pressing the 'INFO' button? This little button will toggle between camera info on display/no info on display (when the display isn't in use to display pictures).
what model & what the specific hapen to the dsplay
