Dell Inspiron B130 Notebook Logo
Posted on Dec 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows xp won't boot up and i end up getting this blue screen with the a stop error on it...
Anonymous
Level 2:
Sergeant:
  • Expert 244 Answers
  • Posted on Dec 17, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
244
Questions
0
Helped
54571
Points
595
Sometimes BSOD are caused either by Software or Hardware problems, you can start running the diagnostic test first on the computer to check for hardware problems.
Try removing any external devices first (Ex. USB devices) then run some diagnostic test:
1. Turn on computer
2. Tap F12 continuously on the Dell logo screen
3. Select Diagnostics
4. Follow on screen instructions
4. Wait for the test results (approximately 10-15min.)
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Solution will be restoring it back to factory settings.
1. Turn on computer
2. Tap F8 continuously on the Dell logo screen
3. Select Repair computer
4. Follow instructions... then select "Dell Factory Image Restore " on the recovery options
5. Follow instructions
6. Wait for 20-25min. and computer now is back to factory settings
Hope this helps
616ab1t5
Level 1:
New Friend:
  • Contributor 11 Answers
616ab1t5
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
2901
Points
25
Switch off the pwr, open the case and ensure that the RAM is correctly seated.
Anonymous
Level 2:
  • Expert 233 Answers
Anonymous
Expert
Level 2:
Answers
233
Questions
0
Helped
72336
Points
588
There are two possibilities for this problem, hardware problems or operating system, the most easy way is to re-install Win XP
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Dell latitude e4200 restarts with blue screen
Sounds like the image doesn't have the right drive controller driver included. Could be because the image was created on a different laptop or could be the drive controller is configured differently. You can confirm this from the STOP error code on the blue screen
Go into the BIOS setup (probably F2 at boot) and see if the controller mode is set to AHCI. If so, set it to compatibility or combined(?) and try again.
Either way, if you've installed an image for the wrong hardware, you probably should do a remedial install. Boot from your Windows XP disc and follow the prompts as if you were doing a clean install until you get to the license agreement. At the next screen, it should show you any existing Windows installs and give you a new option to repair. Let this go - it won't touch any user files, just replace all the Windows files with those from the CD. Have your system drivers and service packs handy to tidy up when it's done.
Dell Inspiron 530 Blue Screen
    • 1 Backup all your computer files. This means you need to save important documents like essays, data sheets, presentations, programs, etc. You can easily store it to a flash drive or on a floppy disc.
    • 2 Search for the operating disc that came with the computer. If you have lost it, you can always purchase a new one for your operating system. Remember, in order to repair Windows blue screen of death error, this disc is needed otherwise it just won't work.
    • 3 Now put your disc into the computer and restart your system. It will prompt you to press a key in order to boot from the CD. It may not show up though if your computer isn't set for booting from the CD, so you need go into the computer Bio to change the settings.
    • 4 Now you will see the win xp blue screen error again with words appearing at the bottom of the screen.
      Press continue and hit F8 once you see the agreement document come up.
    • 5 To fix blue screen of death, pay attention to this detail for the next page. You will see a Repair, Delete Partition and Quit options. Push R for repair. If you cannot find this option, it should say Partition which is a part of the computer memory. Fixing blue screen of death was easy, eh?
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
3answers
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
2answers
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
1helpful
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
1helpful
Blue screen on dell svc tag:GSKTL1S.Ox000000ED,0x8734D9EO,0xC0000006 how to fix this error?
Fine..You have reached the Blue Screen of Death (BSoD)..common in Windows Operating Systems. Generally this must be a hardware problem. If parts liek RAM or bad sectors in Harddisk, such BSoD comes, indicating the crash of the OS. Try repairing XP using the cd. If not, go for a format so that the bad sectors in the Hard disk is repaired.
Thank you!
Sabharish
1helpful
2answers
Blue screen
First off next time you get that bsod error message write down the actual numbers on the blue screen those can be looked up for a more accurate meaning to the error.
If you can get a "copy" of Windows XP and use your Valid License number (probably on the bottom or back of the PC on a sticker) it will still work just fine and is legal.
Laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
