20 Most Recent
Acer Extensa 4230 Notebook Questions & Answers
Acer extensa 4230 webcam not found using windows 7
Hi
kindly follow these steps and check if the problem is fixed
1)Press and hold the windows button and press R simultaneously- A small pop will open
2)type devmgmt.msc press ok- device manger will open
3) check for unknown devices listed there
4)right click on unknown device and select scan for hardware changes-it will complete the process
5) now check for your web cam-still not working
6)restart the computer and check.
for immediate fixing of your computer's issue,mail me at
[email protected]. i will tell you how to proceed from there.
Hope your issues will be sorted out...have a great time
Bluetooth problem
Check to make sure that the Bluetooth driver is installed. What are you trying to connect?
Want to increase speed
You can upgrade the RAM providing you have the slots available.The maximum supported RAM in windows 7 is 4GB. You will find the serial number on the bottom of the laptop, possibly in the battery bay. You can use the following scanner to check the required RAM.
http://www.crucial.com/systemscanner/
When i am trying to instaling win xp .getting a
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP
0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE
BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could
mean that there's a serious hardware problem with a hard drive
controller, a driver issue, or even a boot sector virus.
thansk.
How i can boot from usb
if you want to boot a computer from the usb you will have to go into the bios and set the boot media ( HD, CD, USB) so that the computer knows where to search for the os.
Acer 5620z screen going blank but motor still running
There are more than one possibility for this scenario (settings, cable, lamp):
•The display is not set as the primary or active display (such as is the case when set to view in projector-only display mode). Many laptops have either a Function key (such as F4) or a hotkey expressly set aside for presentations (usually at the top right with two other hotkeys). Newer operating Windows systems allow for changing the display mode through holding a Windows key down while pressing the [P] key.
•The monitor data cable is damaged. Sometimes, this can be tested by changing the vertical angle of the display to see if the display shows. (In this case, replace the display data cable.)
•The lamp inside/behind/above/below the display could be going out. (In this case, replace the display lamp.)
The easiest way to test & to give a temporary workaround would be to hook an external monitor to the laptop & to turn on both devices to ascertain if the video output shows on it.
If all else fails, then take it to a technician because the system board could be bad.
How to open the DVD case?
In front of your dvd is a little pin hole place a diaper pin in it and push the case should open .On your computer you can also go to My Computer look under dvd right click on the icon ,when the drop down menu show click eject.
Why my acer AS 4250S not accepted pen drive?
does the drive work in other systems.
what is the error is it windows error driver
or is it a error from the drive .
many drives are fake , manyyyyy drives
it will have a brand name on it an might be real. if no name its bogus.
