Televison & Video Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What 4 digit code do I need to programme into my Time Warner Cable Remote Control in order to operate my LITEON DVD recorder
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Dec 05, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3802060
Points
33142
Hello. Call your Time Warner Cable Company, the number is on their bill. They will be able to assist you. Regards, Joe
I'm trying to program a magnavox converter box with a universal remote model UR5U-8780L-TWT. I need the code for this please.
Hi Jerry, This is from the link below.........
The Time Warner Cable CLIKR-5 is designed to offer complete control for all digital, HD and DVR set-top boxes. The UR5U-8780L is factory programmed to operate Scientific Atlanta/Cisco and Samsung set-top boxes while the UR5U-8790L is factory programmed for Motorola set-top boxes.
Time Warner Cable CLIKR 5 Universal Remote Control
1helpful
Will the URC-04-1 remote control operate my Liteon DVD player/recorder if yes could you give the codes, luv ya all
It seems that there is no direct setup code to this brand DVD player, with this remote control. Anyway, you can do a code search method to find out, if there is any codes in this remote control for the said DVD player. If you do fail in this code search method too, there is no other way than buying a new remote control, which have setup codes to Liteon DVD player. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
I purchased a Magnavox Digital Viedo Disc Recorder & Video recorder ZV427 MG9 A. While setting up the DVD player; I was advised by Comcast to switch from their remote control to the Samsung report...
I have a Samsung Blue Ray and haven't had a lot of luck with getting the remote to control anything but my Blue Ray and documentation is hard to come by. I just posted this solution on another similar topic but I think you should try the Synergy V remote. I got mine for free from Time Warner but this seems to be a reasonably priced remote and the most versatile. I've spent up to $100 on universal remotes but this free/inexpensive one does the best job for me and I really liked the price:
I've found that you can use a Synergy V Universal Remote which is supplied by some cable companies like Time Warner, RCN etc. You can also buy this remote. This remote does a good job of controlling all my different components including my LG TV, Bose Sound and Cable Box.
This pdf seems to be best reference.
but there a several others out there if you google for Synergy V.
1helpful
Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
32helpful
2answers
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
6helpful
2answers
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Liteon LVW5002 code for Jumbo uni mastercontroller
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
2answers
Need remote control code forphilips hts8100 to program univ-remot
I have a brand new one!!! I can list it on ebay very cheap. You can e-mail me at [email protected].
2answers
Remote control codes
I NEED A MANUALINSTRUCTION BOOKLETFOR MY LITEON DVD DUAL RECORDER PROGRESSIVE SCANNER MODEL NO: LVW -S115GHC TO BE ABLE TOPROGRANNE THE MACHINE.
HOME ADDRES FLAT 69 NISBET HOUSE HOMERTON HIGH STREET HACKNEY LONDON E9 6AL
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
