SOURCE: nintendo ds lite won't charge
Sounds like your battery is toast, buy a new one from nintendo, or ebay.
SOURCE: My nintendo ds won't charge I tired everything is
If you DS isn't charging there are two possible things that could be causing this.
The first one is that the batter inside the DS is shot, in which case you'd have to replace it.
The other one also requires replacement, and that's assuming your charger itself isn't working. Either way, you're probably going to need to replace something.
One way you could tell which is messed up is to try and charge someone else's DS. If that doesn't work then it's most likely the charger.
Hope I was able to help.
SOURCE: son dropped his nintendo DS lite, now it won't
this happend to my sister it dont work anymore had to get a new 1 when ever it dropped it broke a little chip thing inside take it to a gamestop take it appart see what the problem is
SOURCE: my ds lite has stopped charging. we bought a new
theres problly internal problem! maybe some cable connection inside the system is not working!
