Acer Aspire 5500 5570-2609 Laptop Logo
Posted on Nov 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not recognizing networks after water damage
Spilled water on laptop keyboard. Computer shut off. Left it upside down for three days and it came back on. Everything works except it won't pickup networks or show any sign of having a functioning wireless card. When I flip the wireless "switch" on the front it says no device.
Nasser Abunab
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Nov 21, 2009
Nasser Abunab
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
3061
Points
42
Buy a wireless USB network interface card. It looks like a thumb drive with an antaenna. Plug to a usb port, install driver and happy wireless surfing !
Anonymous
Level 3:
  • Master 863 Answers
Anonymous
Master
Level 3:
Answers
863
Questions
Helped
251450
Points
2475
Sorry old chap.  Looks like your wireless ic chip is fried.  Open this thing up and replace with a new one.
Cheers
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Spilled water on my asus laptop
Maybe or maybe not.They can not be opened.
2answers
Water damaged Laptop
Attaching an external keyboard does not help because the keyboard controller is damaged.
I recommend you put your money towards a new laptop as the cost of repair maybe too expensive or beyond repair. Most computer repair shop charge for a quote and may drop this charge if you go ahead with the repair.
If the hard disk is OK then I suggest you remove it from the laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive for backups and data transfer etc.
2answers
I can't switch on the laptop because water spilled
Flip it upside down and remove the main battery, leave in that position to drain water out as much as possible. Take it to a computer technician quickly as possible, chances are it will need a new keyboard, also he will need to check the motherboard under the keyboard for water damage.
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
1helpful
About a week ago I spilled some water on my ASUS U81A laptop keyboard. Put it upside down, turned it off, and took the battery out immediately. Opened up the keyboard to help it dry. Two days later I...
You should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of water on the circuit boards & on other components. On circuit boards, water damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no water seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the water fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
1helpful
Water spilled on the keyborad water now it barely works
shut your PC down and disconnect the keyboard and turn it upside down and let it dry out
I spilled tea on my packard bell easynote
Two things to check.
Open the laptop up and re-connect the keyboard connection. It has a locking mechanism so be sure to unlock that first. Also when you're doing that you can see if there's any water (tea) still in there to dry off.
If that doesn't work, then plug in an external keyboard mate, cause the only other way to fix this is to replace the keyboard, the parts to open up the laptop keyboard itself are intricate and it's much too compicated, plus I've never done that (Seeing as that it's all glued together).
Hope this helps, be sure to rate!
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
