wendell r. inhoffer Posted on Nov 18, 2009
Continues to show lock error when started . have locked and unlocked under all possible conditions.
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Nov 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
3174
Points
27
If this is a mirror lock error you may need to lubricate the stainless steel bat that the scanner rises on. Unplug copier!!! remove top 4 screws and take off glass carefully. put a very small amount of oil on a rag and wipe down the ss rod. Slide the scanner assembly back and forward a few times (carefully) hold only where ir rides around the bar. hope it works. good luck
My 2004 chevy Aveo door locks keep locking and unlocking with car off or on how do i fix this ?
If the door locks on your 2004 Chevy Aveo are continuously locking and unlocking even when the car is off or on, it could be due to a few different reasons. Here are some steps you can take to troubleshoot and fix the issue:
  1. Check the battery: One possible cause of this issue is a weak or dying battery. If the battery is not providing enough power to the electrical system, it can cause the door locks to malfunction. Have the battery tested to ensure it is in good condition.
  2. Check the door lock switch: The door lock switch may be stuck or malfunctioning, causing the locks to continuously activate. Try disconnecting the switch to see if the issue persists. If it stops, replace the switch.
  3. Check the wiring: It's possible that there is a wiring issue that is causing the locks to malfunction. Inspect the wiring harness for any signs of damage or corrosion, and repair or replace any damaged wiring.
  4. Check the door lock actuator: The door lock actuator may be malfunctioning, causing the locks to activate continuously. Test the actuator to see if it is functioning properly, and replace it if necessary.
  5. Check the remote: If you have a remote for the door locks, it may be malfunctioning or sending signals unintentionally. Try removing the battery from the remote and see if the issue persists. If it stops, replace the remote.
If you are unsure about any of these steps, or if the issue persists after attempting to troubleshoot, it's best to take your car to a qualified mechanic for diagnosis and repairs.
tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 • Computers & Internet
WHAT DOES CONTROL LOCK ON A GE GAS DRYER MEAN
push the lock/unlock button for several seconds to unlock the control panel. on some it says lock on some it shows a key
Jan 31, 2015 • GE Dryers
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
18helpful
4answers
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
Blink: 3 - Caps Lock/Num Lock
Memory
Blink: 4 - Caps Lock/Num Lock
Graphics
Blink: 5 - Caps Lock/Num Lock
System board
Blink: 6 - Caps Lock/Num Lock
BIOS
F28 continues to show on display.
Comunication error between motor control unit and Central control unit. Broken wire in the harness.
F01 power glitch: disconnect power for 2 mins verify correct CCU operation
F11 Motor control unit internal failure MCU board failure or broken wire.
F20 No water detected entering machine, pressure switch hose clogged
F21 Long drain Possible cause: Clogged filter, clogged/failed pump
F22 Door lock error Failed lock. corrosion,or broken wires.
F23 Heater Failure Bad heater
F24 Water temp sensor error Failed sensor or heater
F25 Motor Tach error Bad MCU (motor control unit) or broken wire
F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
F27 Overflow condition Clogged drain, pump, kinked hose.
F28 Com error between MCU and CCU (central control unit) Broken wire
F29 Door unlock error bad switch,broken wire,corrosion
F30 Dispenser system error Bad or jammed motor, broken wire
F31 MCU failure due to motor overheating.
F33 Pump drive system error, broken wire, corrosion
rL (prewash)Clothes detect. Remove clothes and retry.
5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
For diagnostics and further info refer to this handy dandy:
DUET SERVICE MANUAL My tip:
http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
3answers
Error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
3helpful
2answers
Kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
12helpful
7answers
Copier Locks up L1 Error Code
there is a locking dial under the left side of the machine that maybey holding the scanner in home position.... be sure its unlocked.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
