I had the same problem
Have you tried lifting the lid where the ink is inserted a few millimetres
While its in startup
i did and it reset itself and is working perfectly
I have something lying on top of the printer all the time im wondering if the weight of it upset the mechanics some how
If things were working before you replaced the new ink cartridges, the chances are that the new cartridges are defective. This is common for aftermarket and refilled cartridges. The aftermarket ink has probably clogged the nozzles. The simple solution is to replace the cartrtridges with OEM cartridges, run the nozzle cleaning utility an number of times (suggest 3x) and align the printheads. This should clear your printer problem.
Please let me know if this works for you. Thanks.
