3 year old KitchenAid Professional 5 plus mixer, 250 Watts. Yesterday it wouldn't turn all the way up so I opened it and found roaches. (yuck, I know. Nothing I can do about that here in Hawaii.) I cleaned them out and it ran fine the rest of the night. Today I tried to use it and it won't turn on at all. I opened it up and looked around and can find nothing visibly wrong.
SOURCE: Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
SOURCE: kitchenaid 250 watts k4ss mixer
The repair manual says that the mixer can make this grinding sound at slow speed, like stir or 2. This is normal, especially until it warms up. This is the sound of the gears turning at slow speed.
SOURCE: KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
SOURCE: Kitchenaid mixer professional motor
DO NOT DO IT. The Hz will destroy the morotr. The transofrmer only converts the voltage. You are better off buying a 220V version.
SOURCE: KitchenAid Professional 5 Plus - Runs at Full Speed
Hi. All of you have the same problem. The electronic speed control board needs to be replaced. This board can be installed without much trouble. The board is modular, remove the old board and install the new one. The wiring is connected by a modular plug.
Goto www.kitchenaid.com enter your model # and search for the parts manual. These drawings will assist you with the task at hand.
If this solution has assisted you, please rate it. Good luck! ricardok45
