Question about KitchenAid ProLine 600 Stand Mixer
I have a KitchenAid ProLine 600 575 Watts Stand Mixer It is only a few years old and has had very few hours of use. From the time I got it I thought it was very loud and noisy. As I increase speed the mixer makes a very loud noise with a high pitched wine. Any suggestions about repairing by my engineer son or a professional?
Posted by mtpinchak on
Anonymous
    New Friend:
  • 3 Answers
Counter top appliance number for Kitchen Aid is 1-800-541-6390 M-F 8 - 8 EDT and Sat 12 - 5 p.m. they should be able to help you
Posted on Oct 22, 2010
Kitchenaid 600 pro
After many years dealing with Kitchen Aid mixers I purchased a pro 600 for my wife as an early Xmas gift. After just a few usages it started making a clunking noise in the gear housing. I removed the housing and discovered the casting is of very poor tolerances and the main drive assembly was lifting from the torque of the motor and causing the gear assembly to lift out of the casting and skipping on the worm gear. I am sure it is going to happen to many more of these units as the casting area that holds the bearing in is to large obviously an overdue mold in the casting process. Time for a recall Kitchen Aid.
Jan 31, 2014 | KitchenAid ProLine 600 Stand Mixer
Kitchenaid mixer on high all the time
I think that the mechanical speed control is stuck. Unless you are not afraid to take the mixer apart, you will need to take it toa shop or return it to the store for another one.
Dec 30, 2012 | KitchenAid KSM95 300 Watts Stand Mixer
My kitchenaid stand mixer is not turning on
Are you sure there's power in that wall outlet? Try plugging something else in there
May 23, 2012 | KitchenAid ProLine 600 Stand Mixer
Have a kitchenaid stand mixer Model # KP26N9XER the attachment hub is not turning correctly it only turns a liitle at a time with a thumping sound. Opened up looked at the gears and their are bits of metal...
Obtain a copy of the Repair Part List for your model from Kitchenaid.com
Download the Service Manual :
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It is not exactly for your model but you can learn a lot from it.
Open up your mixer. Get rid of all the grease. Replace the Worm Gear.
Use fresh Kitchenaid Food Grade Grease on all gears.
Caution: Do not use a screwdriver to pry out the Planetary Assembly.
Jun 20, 2011 | KitchenAid ProLine 600 Stand Mixer
I have a 600 watts stand mixer, one time i put too much flowers and it just stop mixing in the middle and making the loud jam noise. now it won't complete the circle and alway jam half-way and stop...
It sounds like you have a stripped gear. I, too, had this problem when my bride dropped a wooden spoon into the bowl. You'll need to disassemble the mixer and determine the part(s) that need to be replaced. With a google search for parts for your model, you can not only locate the exact part, but can also get exploded diagrams for your model. Very handy indeed for disassembly/reassembly. I'd get the diagrams first and then determine the parts needed.
Hope that this helps you.
Best regards, --W/D--
Jan 22, 2011 | KitchenAid ProLine 600 Stand Mixer
I have a KitchenAid Artisan stand mixer (325 watts/model KSM150), about 5 years old. Lately, when mixing dough for bread or cookies, the motor head of the machine wobbles a bit from side to side. In...
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Feb 20, 2010 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
No Problem
This is "middle of the line" Kitchenaid as far as bowl size and motor strength goes. However, it is a great mixer that will probably fit your needs.
Nov 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid ProLine 600 Stand Mixer Logo
681 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
