You will have to remove the side panel of the tower to expose the motherboard. The PSU (power supply unit) is above the motherboard.
If you read the information on the PSU, you will find out how many watts it is, for example 350W, 400W, 450W and so on.
If your wanting to put in a powerful graphics card to run games like GTA4 or Need for Speed Shift then you will need a power supply no less than 550-600W
Make sure you get a Dell power supply as standard PSU's don't fit in a Dell case.
Regards.
SOURCE: Power supply
The Hp PWRSPLY-250W power supply would be compatible when upgrading your graphics card.
please rate me. thank you.
SOURCE: graphics upgrade for lenovo 3000 K100
did you install the drivers that came with the radeon card... if not your going to have to go to the manufaturers website and get it for the version of windows you have.
SOURCE: Graphics Card Upgrade for HP Pavillion a6600f
if your video slot is a agp try buy a nvidia geforce 7800gs used on ebay cheap and good ;p if u have a pci-x slot u can have a better card also check your power suppy if is enough for it you can ask to a reseller near you cya
SOURCE: should i upgrade my power supply?
First refix both RAM. check its frequency may be it is conflict with each other meory frequency.
Also when you power up the computer press F8 key then enter in safe mode.
Then go to start menu type in run "chkdsk /r" then you see black screen press "y"
then resatrt it then it fix error on harddisk.
This problem is not related with power supply.It is related to RAM memory or harddisk memory.
