I do not supect the basket just make sure it is not blocked with limescale or other debris as this will reduce the flow of steam through your coffee grounds.
if this is ok then check the pressure release valve on the lower chamber it may be open or defective see if steam is coming out of it when your use your machine if you do not get pressure in your lower chamber it can not lift all the water to the top.
i do not know if the pressure release valve is a replaceable part.
