Question about Bialetti Mukka Express
The pressure valve on my Mukka Express doesn't pop up. Instead after 10 minutes the valve is forced off. I rinse it really well and have even put it in boiling water. How do I get it to pop up?
Koral Ilgun
    New Friend:
  • 3 Answers
I have the same problem. I cleaned all the parts, changed the pressure valve, cleaned the gasket, filters, everything. I hear the steam escaping from the overflow valve and if at that point I manually pull the valve up, then it does (barely) pop and steam the milk, but not as well as it used to.
Posted on Aug 05, 2011
  • Koral Ilgun Aug 05, 2011
    I saw this solution in another post which made sense: "the safety valve on the lower boiler chamber is there to release pressure in case too much pressure builds up in the pot when brewing. If you have an 11 mm wrench you can take it out and clean it by pulling on the outside part, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still function as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oil on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve."
  • Koral Ilgun Aug 20, 2011
    I did all the cleaning of the safety valve as I described in another post, but it didn't help. I then ordered a "15mm bialetti valve - silver" fromhttp://www.bialettishop.com/PartsValveEs... and now my mukka express performs as good as new.
Adam Sharif
    New Friend:
I had this problem with my Mukka Express and was determined to fix it myself rather than buy a new valve. after trying various things the solution came to me, I used one of those plastic and metal flexible food ties, removed the plastic and then pushed the flexible metal part through the bronze opening on the valve, poked it about and then blew and sucked through that opening to clear it fully. Next I put it on the stove, fully assembled, without any coffee in and it worked again!
There's no need to buy a new valve, you just need something thin and flexible and you can clear it, even a piece of wire may work.
Hope this helps others as I didn't find any solutions elsewhere!
Posted on Mar 29, 2014
  • BAW30s Sep 04, 2017
    This is an excellent idea which often does the trick. Once I was so desperate, though, that I added about 20% of drain unblocking fluid to the water in the lower vessel and ran it through a few times without any coffee into cold water (not milk) into the upper part until the valve was unblocked and the water started to flow in a milky stream. Push down and release the black button of the valve above frequently if it feels raised and under strong pressure; when unblocked, the pressure should not be high. If the safety valve below starts to leak, turn off the heat at once and keep pushing down and releasing the valve. I would wear goggles, and prepare to make a mess.
1helpful
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I read your reply to same problem about cut out pressure adjustment
Looking at your manual, instead of the actual item since I don't have one, I see 312, 329 and 314. It is possible that 312 the switch is shorted causing the pump to run to pop off and beyond. Item 14 is the pop off valve and if the numbers indicate anything, it is a 175 PSI pop off and is going off early. The switch doesn't have any indication of pressure rating.
The screw and bracket that mounts on the switch may be a pressure adjustment but hard to tell remotely.
Some units like this don't have adjustments, they just pump to a predetermined pressure and stop, being determined by the pressure switch and if the switch fails, a pop off will prevent over-pressuring the tank or system.
If you determine that the screw and bracket do not make an adjustable pressure switch, replace the switch with a like on or one that you can adjust in the range you need. Also if the pop off is going off early, replace or if possible, clean it, they can become dirty with rust.
Is possible that the screw fell out of the pressure switch rendering it "broken" until you put it back in....
Hey, I'm having trouble with my Dewalt 18ga Brad Nailer trigger. Can you send me the directions you have on how to get into this thing? I'd really appreciate it.
For removal of dewalt D51238k trigger valve. Remove the nails.
Remove the pin holding the trigger in place. Then remove two roll pins in the body of the gun just above the trigger (3mm roll pins). With gloved hand, apply air pressure to the gun which will pop out the trigger valve. Use caution because the valve could come out with force. Try with low pessure first, then increase as needed. If you are removing the trigger because the gun will not fire, (only puff of air from trigger area), suspect problem in the head valve instead (usually, trigger valve is bad if air leaks from trigger when you connect air ). Good luck
1helpful
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in with...
I had the same problem and saw this solution in another bialetti mukka problem report, which made sense: "the safety valve on the lower boiler chamber is there to release pressue in case too much prssure builds up in the pot when brewing. If youy have an 11 mm wrench you can take it out and clean it by pulling on the outsidepart, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still funtion as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oul on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve."
2helpful
I was looking for instructions for a Bialetti Mukka Express ;and also does this unit make espresso?
Here is the owner's manual. Also, by filling the filter with espresso grounds and using water, you are making espresso. It only becomes cappuccino by adding milk.
http://www.google.com/url?sa=t&source=web&cd=5&ved=0CEcQFjAE&url=http%3A%2F%2Ffantes.com%2Fmanuals%2Fmukka_express_manual.pdf&rct=j&q=Bialetti%20%22Mukka%20Express%22%20owners%20manual&ei=JdWATp7uLcu4tge7prWNAQ&usg=AFQjCNEIi9J9flq7TmgLWUYOiLF4KatH3g&sig2=UqfzIzEfVCpfZv60t1wClg
2helpful
I cannot unscrew the top...i have waited until cool and taken out the pressure valve...it still wont unscrew! help !!
dip the top part upside down in warm water, make sure the bottom doesnt warm up, the material from the top will expand and comes loose from the bottom, it might need powerfull hands anyway good look
5helpful
2answers
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in...
7helpful
Bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Espresso irregularly spurts out the center post
could it be that the gasket is oversized and it covers the small holes ?
1helpful
Mukka Express spits out coffe from the screw section & steam valv
it did that to me too, so I reduced the amount of milk to the indicated level inside. No more mess after that.
Mukka valve broke
HAVE YOU TRIED SYDNEY?
Bialetti Mukka Express Logo
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
