Question about Bialetti 20-9 Stove Top Espresso Machine
I melted the rubber seal in my 4 cup Bialetti coffee maker. I forgot to put the water in it. Now I am trying to remove the smelly melted rubber from inside the threads and and coffee holder. Please how can O remove it and still be able to drink coffee from it?
Posted by barrytedward on
bradley_r_sm
    New Friend:
I have the same problem. Scraped most of the rubber off mine with a knife. I'm going to try steel-wool next, as the whole thing is stainless-steel (or perhaps in your case, Aluminium), it should take a good sound beating.
I wonder if there are any solvents that would dissolve the rubber?
Posted on Oct 10, 2012
5 Related Answers
Anonymous
  • 67 Answers
SOURCE: Need a k-cup holder for my platinum coffee maker
you are talking about the black funnel? then check ouit http://stores.ilikenew.com
Posted on Nov 17, 2010
Anonymous
  • 11 Answers
SOURCE: Rubber Seal for coffee screen needs replaced
it is actually a silicone seal. if anyone finds them outside of breville, please post. i have gone through already. i would love to buy a bag of 10 and be done with it.
Posted on Aug 13, 2010
Anonymous
SOURCE: I want to change the rubber seal on a bialetti coffee maker
Just take your coffee maker apart and look under the top part. You'll see the seal and the metal filter. They are only held there by the friction of the seal itself (and any crud that might have built up by now). So with your finger nail or a butter knife pull out the seal, and with it will come the metal filter. It's not a bad idea to do this every time you clean your maker anyway. To replace with old or new seal, just put it back in place: first metal filter, then seal. Easy as can be.
Posted on Aug 23, 2010
Anonymous
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
Jason
  • 218 Answers
SOURCE: coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
Posted on May 28, 2009
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
I have changed the rubber seal and now I get no coffee!!
check under that plate with holes and make sure water is just under safety valve inside. make sure plate holes are open and the pipe that delivers the coffee
How can I clean the melted rubber seal from a Bialetti Top Espresso Machine?
I scraped off as much melted rubber as possible - using my thumb nail - then used a product called Goo Gone to melt the remaining rubber. I put Goo Gone on an old cloth and rubbed off the remainder of the rubber - again with my thumb nail.
Hello! I change the rubber sealer to my Bialetti 12 cup yesterday and since then the water stays in the bottom and does not rise to the top. The sealer is properly put in. I have not done anything...
This happened to me, too....the gasket needs to be broken in so that it seals properly, which will happen once it's been used several times. In the meantime, just tighten the pot together extra tight and that will help to seal the gasket properly. After several uses, you won't have to tighten it so much and can go back to how you've always done it. I hope this helps!!
4helpful
How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Bialetti 20-9 Stove Top Espresso Machine Logo
Top Bialetti Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
