Bialetti 4cup Stainless Steel Espresso Coffee Maker Logo
Question about Bialetti 4cup Stainless Steel Espresso Coffee Maker
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine, because I know that can clog the maker. What happened was nothing. The water heated up and came to a boil, but nothing showed up in the top receptacle. What is going on?
Posted by nmanveld on
Anonymous
    New Friend:
  • 6 Answers
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
Posted on Apr 20, 2011
Steam blows out of valve rather than up through the top
Make sure your grinds are ground properly. If you try a different coffee and it still continues the valve may be no good. Also remove the screen on the top half and make sure the passage to the top is clear.
For more information visit: www.CeriniCoffee.com
I melted the rubber seal in my 4 cup Bialetti coffee maker. I forgot to put the water in it. Now I am trying to remove the smelly melted rubber from inside the threads and and coffee holder. Please how can...
I have the same problem. Scraped most of the rubber off mine with a knife. I'm going to try steel-wool next, as the whole thing is stainless-steel (or perhaps in your case, Aluminium), it should take a good sound beating.
I wonder if there are any solvents that would dissolve the rubber?
I just bought the Bialetti Moka Sound 6 cups for 1 day. And it is not sound. What should I do? I have read one said that I have to change the battery at knob but I have no idea to open it at all. Anyway,...
First I'm not a Bialetti tech. But I have worked on may brands of professional espresso machines.
* When you mentioned this stove top model 'sounds off' I just had to check it out. The you tube videos are going nuts over this 'cute' brewer. Especially the Italian tubers.
* I found a link for you to change the battery. It's more obvious on the white cap model. So I'm guessing you have the black knob style (or they changed it to make it more visible.) Cute music but notice all the vids have the steaming louder than the music.
Aloha, ukeboy57 (link below)
Changing batteries: https://www.bing.com/videos/search?q=Bialetti+Moka+Sound+battery&&view=detail&mid=91C18C780FD6FD17C0F591C18C780FD6FD17C0F5&&FORM=VRDGAR
2answers
Corrosion on my Bialetti Moka stove-top
You can buy a new one or Google "Bialetti parts".
4helpful
I want to change the rubber seal on a bialetti coffee maker
Just take your coffee maker apart and look under the top part. You'll see the seal and the metal filter. They are only held there by the friction of the seal itself (and any crud that might have built up by now). So with your finger nail or a butter knife pull out the seal, and with it will come the metal filter. It's not a bad idea to do this every time you clean your maker anyway. To replace with old or new seal, just put it back in place: first metal filter, then seal. Easy as can be.
3helpful
2answers
My bosch stove top won't turn on, it just flashes a blinking red light. help!
The red dot light flashing indicates that you have activated the child safety option so the stove will not turn on. Hold your finger on the button for at least 4 seconds to turn off the safety option.
8helpful
Handle of Bialetti Moka Express 10 cup...
There is a tiny pin at the top where the handle slides into a slot between 2 aluminum walls. That pin needs to be "punched" out. I used a nail and hammer, but a tiny nail punch might be safer if you have one.
I need a new funnel for my vev vigano kontessa 6 cup stove top espresso
Usually most stove top espresso makers manufacture these parts to the same standard. Take your old funnel, go to a kitchen store where they sell Bialetti, and compare their funnel size to your funnel size (for the same size put). I noticed that usually, it's the rubber gaskets that may differ slightly. Or you could email customer service of www.vev-vigano.com.
Open Questions:
See all Bialetti 4cup Stainless Steel Espresso Coffee Questions
Top Bialetti Coffee Makers & Espresso Machines Experts
Marvin
Marvin
David Shaub
Kolbrun...
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
