Bialetti Venus 4 cup stainless steel stovetop espresso maker Logo
Question about Bialetti Venus 4 cup stainless steel stovetop espresso maker
My bosch stove top won't turn on, it just flashes a blinking red light. help!
Posted by tjk1572 on
Anonymous
    New Friend:
The red dot light flashing indicates that you have activated the child safety option so the stove will not turn on. Hold your finger on the button for at least 4 seconds to turn off the safety option.
Posted on Jan 23, 2011
  • Brenda Alfred Jun 22, 2013
    My Stove is not working ... the red minus signs or red short lines if you want to call it that is flashing and not going away and I am not able to turn on the stove .... Please help me
    I have tried holding down the key lock sign and the main power and all what is said on the manual ... even turned my main power supply off but nothing works
Anonymous
    New Friend:
I your stove is induction type, you may try place some other small pot in the same heating area. I have the same problem - my induction stove (AEG) doesn't detect espresso maker, because it is to small. May be anyone has better ideas, how to solve this problem?
Posted on Aug 01, 2010
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
6helpful
1helpful
2answers
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
2helpful
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
1helpful
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
10helpful
2answers
BOSCH CERAN
2helpful
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Top Bialetti Coffee Makers & Espresso Machines Experts
Marvin
Marvin
David Shaub
Kolbrun...
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
